Date/Time: Wed, 30 Sep 2026 01:04:48 +0000
Drawing tools
View Count: 1183
[2021-09-21 08:16:12]
nicktrader - Posts: 813
Is it possible that some drawing tools will be revised? I work a lot with OHLC Ray, Horizontal Ray and Horizontal Line non ex
OHLC Ray:
Here is disadvantageous that "Cut drawing here" is not possible. Maybe an OHLC Ray non extended will be added.
Horizontal Ray + non ex
I noticed here some disadvantages
- "Copy and move..." is not very handy
- Setting a date/time is not possible
Many thanks
[2021-10-09 14:47:20]
I am well aware that many of my suggestions are simply not responded at all.
Maybe you could at least offer an OHLC not extended, so that you have the option to extend them or cut the OHLC Ray.
Handling of the OHLC is much easier than the other lines I mentioned.
Many thanks
[2022-03-27 10:59:30]
User676363 - Posts: 90
I am trying to cut an OHLC ray and the command isn't available.
I like this tool because of the date and price formatting available on it.
The other tools don't offer the ability to automatically apply price and time and also tell if it was a O, H, L, or C.
However, the problem I have is when backtesting, if I select "Extend Until Futures Intersection" which keeps the charts clean, the information disappears off the right side of the chart if the intersection isn't on the chart, leaving only the line and no info.
I need that information to be visible, so I thought I would just cut the line. But I can't.
1. Can we offer a cut feature for these lines, please?
2. Can we offer some way to display the text in the viewable chart area?
Perhaps offer a horizontal alignment option (left, center, right) and calculate that based on the number of candles shown on the window rather than based on the intersection point?
Thank you.
[2023-06-05 12:37:46]
User251043 - Posts: 50
I also would like to have an OHLC ray that could be cut.
If an OHLC can't be cut, is it possible to have an horizontal ray with a "magnet"?
Thank you!
[2023-06-07 04:47:16]
@251043
As a "magnet" on the Horizontal Ray you can also press the "Shift" key.
[2023-06-07 08:15:58]
Nick,
Thank you!! :)
That's exactly what I was looking for. Thank you again!!!
