Date/Time: Fri, 06 Nov 2026 08:24:28 +0000
Alert for new Order or execution of order has been placed
View Count: 1117
[2021-09-20 09:10:27]
User230940 - Posts: 121
I am playing with the Alert Studies.
Is it possible to get alert in case a new Order has been placed including the Ordertype and the Value and so on?
regards
Carsten
[2021-09-20 13:53:47]
Yes you can get an alert for this. Refer to:
Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications)
[2021-09-21 05:51:36]
Thanks.
I would like to see the Alert in a Spreedsheet. Because of that a Study would be necessary.
Is it possible?
regards
Carsten
[2021-09-21 15:21:12]
We are not exactly sure what you are wanting to do in terms of getting an alert into a spreadsheet. The first thing to look at is the Window >> Alert Manager, which gives you the Alerts in a tabular format. Refer to the following for more information:
Window, CB and CW Menus: Alert Manager (Window)
If you are looking for the number of alerts, you can use the Color Bar Based on Alert Condition study which has a Subgraph for the Sum of Alerts. Refer to the following:
Color Bar Based on Alert Condition: Using the Sum of Alerts Subgraph
