Date/Time: Fri, 06 Nov 2026 08:27:32 +0000
Is their a way to condense only the evening Session on a chart ?
View Count: 666
| [2021-09-16 16:14:10] |
| GravisHTG - Posts: 321 |
I am now Using a 15M chart with evening session that include time between 16h and 9:29:59. I would like to condense those data in 2 to 5 bar depending on what I like , as for what I am doing , only some information are important and to keep the evening session takes a lot of space on the chart for nothing as their is not much VOLUME. I can do a volume chart or a Tick chart , but I like time chart for Normal market hours. So, is their a way to do condense only the evening session ? thanks in advance. Date Time Of Last Edit: 2021-09-16 16:24:18
| [2021-09-16 16:47:21] |
| John - SC Support - Posts: 48449 |
There is not a built-in way to do what you are asking. You would have to create your own chart bars using a custom study to do this. If you are interested, refer to the information here: ACSIL Interface - Custom Chart Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
