Date/Time: Fri, 06 Nov 2026 08:27:31 +0000
Strange NQ DOM
View Count: 876
| [2021-09-16 07:49:55] |
| User877753 - Posts: 152 |
Hello, Strange NQ DOM (going on for a couple of days) : see attached screenshot. Thanks for your help. JM |
| [2021-09-16 10:01:18] |
We are not sure why this is happening in your case. Disable the use of Custom Symbol Settings. Instructions: Global Symbol Settings: Disabling Custom Symbol Settings See if that resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
