Date/Time: Fri, 06 Nov 2026 08:27:34 +0000
Chart Replay window - Compact option
View Count: 774
| [2021-09-16 00:55:31] |
| User629461 - Posts: 213 |
Are you ablt to provide an option for a compact Chart Replay window (ie something similar to compact tool value window)? It takes up a fair chunk of real estate on the screen...
| [2021-09-16 00:59:03] |
| John - SC Support - Posts: 48449 |
There is not a "Compact Chart Replay" window. But, once you start the replay, you can close that window and then control the Play and Stop from the pulldown menus (Chart >> Replay Chart >> Play/Pause ...).
| [2021-09-16 03:00:32] |
Yes I am aware of that function. However, I advance the chart bar-by-bar manually using the << and >> buttons, and as such the Replay window is always open.
| [2021-09-16 13:55:03] |
Understood. We have tagged this as a Feature Request.
