Date/Time: Fri, 06 Nov 2026 08:27:18 +0000
Spreadsheet across multiple Instances
View Count: 950
| [2021-09-15 20:50:20] |
| User754053 - Posts: 15 |
Dear Sir or Madam, is it possible to use live data collected from a spreadsheet of Instance-1 within another Instance? I tried to select the spreadsheet from instance 1 when creating a spreadsheet study in instance 2, but those data was not available, like a new spreadsheet would have been opened. Though if I open the spreadsheet in instance 2 by using File->Open Spreadsheet, I am getting all that data I also have in Instance 1. Just cannot use it... I guess sharing data-folder - what maybe could work - (while still using different chartbooks) is not a good idea? |
| [2021-09-16 00:33:30] |
| John - SC Support - Posts: 48449 |
Sub-Instances are their own entities, therefore they do not share data. The reason why you saw the Spreadsheet in Sub-Instance 2 is because the first time you instantiate a Sub-Instance, it copies all the data from the main instance. Therefore, it can look the same as the main instance. But from that point forward, the sub-instance is it's own installation and has it's own data and data files. Refer to the information starting at the following link and the following 3 sections: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Source of Data for Sub Instances For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
