Date/Time: Fri, 06 Nov 2026 08:27:18 +0000
Adding live U.S Equities
View Count: 856
[2021-09-15 20:38:22]
MetaTradingVR - Posts: 33
New user here and having a hard time getting my Sierra Charts activated with equities data. Is it required to activate the Denali data and then add U.S equities data? Just to make sure I'm doing this correctly, I have to reload a $$$ balance into my account before adding the data services?
[2021-09-16 00:29:53]
The U.S. Equities are part of the Sierra Chart Exchange Data Feed (not the Denali Exchange Data Feed, they are two separate data feeds). Therefore, you will want to follow these instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
The first step in the instructions is how to add funds to your account to pay for the data feed. In this case, there is a $25.00 USD per month data feed fee and then $10.50 USD per month for the U.S. Equities exchange. The data feed fee is pro-rated, so you will only pay about $12.50 USD for the remainder of the month (you will be shown the exact amount when you activate the connection). But you will have to pay the full $10.50 for the exchange for the remainder of the month, as the exchanges do not pro-rate.
Then, you will be paying the full amount $35.50 on the first day of each month, which is different from your Usage Time renewal. So ensure you have enough funds in your account prior to the end of the month in order to renew the data feed (and of course, enough funds to renew your Usage Time, whenever that is due).
