Date/Time: Fri, 06 Nov 2026 08:27:34 +0000
Is sc.GetOrderFillEntry() the only method to get info on a filled order?
View Count: 1205
[2021-09-15 20:34:18]
Pawel_Szpak - Posts: 48
If I have an internal order Id, but it is no longer found with sc.GetOrderByOrderID (due to being cleared), is the only and quickest method to find the data for that order Id, to loop through all the available orders using (sc.GetOrderFillArraySize() - 1) --> 0 and sc.GetOrderFillEntry() until I find the one that matches the internal order ID I'm interested in?
Alternatively/Additionally does anything put into [Type: SCString] s_SCNewOrder::TextTag on an entry order, also get copied to a text tag for any attached orders?
[2021-09-16 10:51:32]
Sierra_Chart Engineering - Posts: 25390
Yes this is correct if the order is no longer in the order list. However, the idea would be to get information about the fill, before it is cleared. As soon at the order is filled.
No.
Date Time Of Last Edit: 2021-09-16 10:51:39
