Date/Time: Fri, 06 Nov 2026 08:27:25 +0000
RSI Study Inputs Changed
View Count: 795
[2021-09-15 15:54:09]
KXRCap - Posts: 70
This upgrade will change the saved defaults on some of your indicators.
Example - I use multiple time lengths in RSI-W to judge momentum and it defaults all of them to 10 in length and changes it from a Wilders Avg. to Exponential. This is the same if you try to apply your study collection. Go back to 2304!!!!
[2021-09-15 16:07:01]
KXRCap - Posts: 70
So, when reverting back to 2304 and then loading .cht it takes all RSI indicators and gives them a time length of 1...
This sucks...
[2021-09-15 16:21:31]
We are aware of this and we are correcting the Study Input indexes for this study now. This was a mistake by one of the programmers.
[2021-09-15 16:36:14]
KXRCap - Posts: 70
GREAT. But nobody should save any .cht that has an RSI.
It effects me quite a bit because I use the RSI as derivative in many custom indicators.
[2021-09-16 18:44:44]
Sierra_Chart Engineering - Posts: 25390
We have corrected the RSI study Input ordering back to normal. We do apologize for this. The programmer who did this, was just reorganizing the Inputs to be orderly and did not realize the consequence to existing studies on a chart.
Update to prerelease 2310 (which was actually released yesterday) :
And then you need to access your backup Chartbooks if you have saved them on a version with the reordered RSI inputs. Instructions:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
Date Time Of Last Edit: 2021-09-16 18:45:13
