Date/Time: Wed, 25 Nov 2026 07:55:55 +0000
How to adjust the font size of drop down watchlist?
View Count: 1271
[2021-09-15 14:29:21]
ticinotrader - Posts: 431
Dear Support,
I am using the Control Bar's dropdown Watchlists function to quickly change chart symbols.
Can you please tell me, how can I change the font size/type of the symbols in the dropdown list?
I already know how to change the font type/size of every other SC components, but simply can not figure out how to adjust the Control Bar's DropDown watchlist, so it displays quite big letters that are not in sync with the other SC platform fonts.
Please see the attached image for an example.
Thank you for your advice in advance!
image20210915_162401.png / V - Attached On 2021-09-15 14:25:33 UTC - Size: 84.32 KB - 393 views
[2021-09-15 14:51:48]
User391959 - Posts: 19
+1
Dear Support
I can confirm that for a few days I have the same issue.
I would like to see the smaller letters in the dropdown list as they used to be before.
Please note:
My Windows10 Font Size settings have not changed, it seems to be a topic that is only related to SC.
Thanks for your help.
[2021-09-15 15:31:34]
For me, this is not a new thing (I do not use Windows either), the control bar drop down list fonts have always been quite different than other fonts of the platform.
[2021-09-15 23:05:47]
User90125 - Posts: 715
+1
Please consider this for a [Feature Request], if no other solution is readily available.
Thank you.
[2021-09-16 00:56:50]
This has been tagged as a Feature Request.
[2025-09-09 21:50:23]
At some point a Graphics Font option for "Control Collection Non Button Combo Controls" was added which controls the font in the "Watch List" control bar item along with other items like it.
[2025-09-10 06:07:09]
Thank you John - yes this works properly since long time and the relevant font settings automatically follow other UI font types.
image20250910_080444.png / V - Attached On 2025-09-10 06:06:44 UTC - Size: 117.39 KB - 252 views
