Date/Time: Fri, 06 Nov 2026 08:36:54 +0000
Different target and stop orders according to different order quantities
View Count: 619
[2021-09-13 14:45:59]
User58776 - Posts: 18
Dear,
is it possible to setup the trade window, so I can have different attached stop and (target)limit orders for different order quantities.
E.g. if I chose the order quantity 6, I want to have stop orders of 2 points and target orders of 4 points.
However, if I chose the order quantity 4, I want to have stop orders of 3 points and target orders of 6 points.
Is that possible? And if yes, how do you set this up?
thanks in advance
best regards
Jeroen
[2021-09-13 15:23:13]
If we are understanding this correctly, you want to have different offsets for your attached orders based on the order quantity. If this is the case, then the way to do this is to have different Trade Configurations setup for the different quantities. Refer to the following:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
