Date/Time: Fri, 06 Nov 2026 08:27:35 +0000
[Programming Help] - Time and Sales data - recalculation problem
View Count: 1110
| [2021-09-12 10:39:38] |
| User411647 - Posts: 22 |
Dear support I am working on study based on Time and sales data When I want to change study settings or any change so SC stop working during recalculation After restart SC I have to temporarily disconnect datafeed and then open chartbook, connect datafeed to make it work So changes are possible when disconnect datafeed c_SCTimeAndSalesArray TimeSales;
sc.GetTimeAndSales(TimeSales); if (TimeSales.Size() == 0) return; for (int TSIndex = mojIndex - 1; TSIndex >= 0; --TSIndex) .................................. |
| [2021-09-12 12:58:11] |
We do not understand what your question is.
| [2021-09-12 13:12:31] |
why sierra freezes when i use my custom study ???
Date Time Of Last Edit: 2021-09-12 13:30:25
| [2021-09-15 15:48:51] |
You need to check the processing of the study and make sure it is efficient when processing the time and sales data. Can clearly it is taking too much CPU time and not efficient. You need to minimize the number of time and sales records getting processed at once. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-15 15:49:32
| [2021-09-15 17:14:09] |
Thanks for advice is it related to this? // Zero elements from the first index that was written to last time, to the
// first index that was written to this time. for (int SubgraphIndex = 0; SubgraphIndex < sc.NumberOfArrays; ++SubgraphIndex) { for (int DataIndex = EarliestIndex; DataIndex < OutputArrayIndex; ++DataIndex) sc.Subgraph[SubgraphIndex][DataIndex] = 0.0f; } // Store the last index that was written to EarliestIndex = OutputArrayIndex; if you allow me, I will send you a private message with the complete code Date Time Of Last Edit: 2021-09-15 20:01:02
| [2021-09-16 17:03:54] |
I set the number of time and sales records to a minimum and it has no effect
Date Time Of Last Edit: 2021-09-16 17:07:33
