Date/Time: Fri, 06 Nov 2026 08:36:51 +0000
The Idea of a Container Study ( your new Extreme study base on multiple one) - Is it possible ?
View Count: 826
| [2021-09-11 16:13:19] |
| GravisHTG - Posts: 321 |
------ EDIT Just had the idea now ( dont know if possible ) : a study that you can add as many study you want inside of it, it can be name Container Study. Like First line can be : Chooose the amount of study you want to use. And if we dont use the extra , it does not bug the container either. second line : on how many bar you want to use that container and then each substudy selector appear base on the first line choice I dont think we need the Subgraphs and Alerts in the Container study settings. the container will overwrite the subchart for sure , and i think hide, draw study underneath main price and scale have to be seperated for each study in the container. The rest of the options will have to be think about. The only thing I cant visualize is , how to make it that we can open the study settings inside the container study settings. We can even implement this on the spreadsheet but it will have to add another <dot> in the name. EX : for the container with ID4 the naming will become : ID4.SG3.SG2 so you target the third row ( first study ) of the container with his SG2 parameters. An example of a study I build. 2 X RSI 2 X color bar above or below /that use different settings. 1 X line study - to add the mid line all in the same subchart I had to implement them all in manually on all my charts because its an add on study to all my other studies and I dont share the exact same setting on each charts. I really wonder if this is doable , and do you think this can be hard to implement ? thanks in advance. ( if any user think this might help him , click on thank you or reply ! :) ) so I can know if other people would like this. Date Time Of Last Edit: 2021-09-12 18:37:00
| [2021-09-13 12:50:37] |
Is this possible to implement for you guys one day ? Or its a pipe dream ? thanks |
| [2021-09-13 13:52:07] |
You can develop whatever you want using ACSIL: Advanced Custom Study Interface and Language (ACSIL) Everything you want to do is possible. You do not need to rely upon us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-13 13:52:16
| [2021-09-13 14:20:43] |
so , this with the ability to load the other study setting inside the container and not just seeing it in each row in the parameters and you can target 1 parameter out of all the studies in the Spreadsheets for autotrading alert etc. or a good backtester that use all core and gpu to analize different number in the study parameter and bring out the results, like in ninjatraders ( they only use cpu ) those 2 things are 100% doable in ascil right ? It will clear my mind on the feasability of those 2 project, and I dont want half of it, I want it at least like I describe. Or else , its not worth investing. And you , are the real pros of this software. thanks in advance. Date Time Of Last Edit: 2021-09-13 15:17:55
