Date/Time: Fri, 06 Nov 2026 08:41:33 +0000
Charts Value window not showing
View Count: 958
[2021-09-08 14:55:51]
User90927 - Posts: 38
My tab is clicked in Charts Value /Crosshair.
The crosshair is working but the Charts value window has totally disappeared.
How do I get it back?
[2021-09-08 15:47:42]
Tonkadad - Posts: 235
go to "Window" on main tool bar then "Reset Windows"
[2021-09-08 17:16:39]
Also make sure that either Window >> Tool Values Window or Window >> Compact Tool Values Window has a check next to it, denoting that the window should be opened when the crosshairs is active.
