Date/Time: Fri, 06 Nov 2026 08:41:47 +0000
plusieurs comptes
View Count: 1005
| [2021-09-07 19:52:57] |
| User397823 - Posts: 2 |
Bonjour ,je n'arrive pas a me connecter au data sur mon 2ème compte. Connect to data feed/ Service package does not support this function or account is expired. Rithmic Trading(not enabled on package) Je pense que l'on peut avoir 3 comptes? merci d'avance |
| [2021-09-08 10:10:14] |
This account you have posted this message with and you are apparently using with Sierra Chart, is expired. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update/Set" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-08 20:02:03] |
| User699831 - Posts: 6 |
mon compte est actif jusqu'au 2021-10-30 23:59:59 UTC 53 Jours En fait ,il y a un vieux compte AC124766 avec la même email . Je pense que le plus simple est d’annuler ce compte . Je travaille avec le compte philo875. Pouvez-vous supprimer le compte AC124766 qui crée des problèmes ? merci d’avance. Casuccio Philippe Date Time Of Last Edit: 2021-09-09 10:58:18
| [2021-09-09 16:47:41] |
| John - SC Support - Posts: 48449 |
Yes, we can remove the other account for you. Just continue to use the one that you have currently active.
