Date/Time: Fri, 06 Nov 2026 08:41:35 +0000
FEATURE REQUEST - TRADE DOM
View Count: 810
| [2021-09-07 19:00:35] |
| User993067 - Posts: 200 |
I would like to request an additional feature to the Trade Dom, my apologies if this is the incorrect forum. The current BID and ASK Volume is can be set to clear on new entry or clear manually. Would it be possible to add an open and close marker ( directional by color) to the graphic somehow, This way each time the bid ask volume is cleared there is a directional notation of movement since last cleared. Also would it be possible to capture volume totals and sum these above/below the data as it the bid ask volume builds and then have these totals reset again upon clearing the data. This is similar to VBP tool ( which i use but the interval whether time or volume is fixed) and showing the totals for the selected interval, only with this feature the intervals are resettable by the trader. I find myself at various points within a trade needing orderflow data for the moment at hand, this would help tremendously. Or is what I am asking for an actual clearable VBP for the trade dom? |
| [2021-09-08 15:46:13] |
| John - SC Support - Posts: 48449 |
We have set this as a Feature Request. But, we do want to point out the Volume by Price Reset Button study that could help with what you want to do: Volume By Price Reset Button For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-08 16:01:00] |
Fantastic, I had no idea this was available for VBP.
