Date/Time: Sat, 27 Apr 2024 03:28:29 +0000
How remove a pending order automatically
View Count: 1048
[2014-03-24 14:21:30] |
Sawtooth - Posts: 3976 |
Try this in cell J27: OR(AND(J3>0,J8=0,K5),AND(J3<0,J8=0,M5)) |
[2014-03-24 17:56:47] |
You need to use Cell J27: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CancelWorkingOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
