Date/Time: Fri, 06 Nov 2026 08:41:48 +0000
Connection to cqg
View Count: 1005
| [2021-09-06 18:40:00] |
| User548453 - Posts: 8 |
I cannot access cqg as I do not have username and password I am trying to set up a non Prof tradimng for CME only I have purchased denali data I gave done exchange agreements My account has not been verified yet I would like to starg trading and have funded AMP account a week ago please can this by resolved ASAP |
| [2021-09-06 19:30:06] |
| John - SC Support - Posts: 48449 |
You need to get with AMP and find out what is happening. If you are supposed to be able to verify through the portal that we created, then they need to update your account to allow this to occur. Otherwise, if they have you setup to use CQG, then you will need to get the CQG credentials and then follow these Setup Instructions to connect to that CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
