Date/Time: Mon, 09 Nov 2026 20:11:11 +0000
Limit touch chase as parent order question
View Count: 875
| [2021-09-03 19:57:52] |
| User900285 - Posts: 102 |
Hi I have my chart DOM configured in a classic way when I click on the buy column below the price it submits a limit buy with my attached orders. Is there any way to have my parent order be a limit touch chase order when left clicking on the DOM? If the answer to the above question is no, what would be a quick way of submitting a limit touch chase order (with attached orders) about 20-30 ticks below or above the current price? Thank you |
| [2021-09-03 21:02:01] |
| John - SC Support - Posts: 48477 |
The Limit Touch Chase is not setup as one of the options for the Buy/Sell columns (as you have noticed). The quickest way to do this would be to add the Limit Touch Chase order to the Trade Menu, that way it is part of the right-click options. Then just right click and select the option and it will place the order at that level. Refer to the following: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
