Date/Time: Wed, 25 Nov 2026 22:08:07 +0000
Use Tradier Brokerage
View Count: 1812
| [2021-09-02 18:32:49] |
| edwood - Posts: 3 |
Hello. Is it possible to connect Sierra Chart to a Tradier Brokerage account? https://tradier.com Thanks and kind regards |
| [2021-09-02 19:05:58] |
Looking at their website, they have a special API to connect to them. To begin with, we do not have this API, so it is not possible to trade through Sierra Chart to them. Second, we do not build special APIs, so we would not be interfacing to them unless they built a DTC interface.
| [2025-04-22 20:44:13] |
| YSS - Posts: 120 |
For anyone revisiting this thread, they do support Sierracharts and have a DTC interface
| [2025-04-22 21:10:50] |
| SC Support - Posts: 2116 |
We do not believe this to be the case, we do not see corroboration for the claim on the Tradier website.
| [2025-04-22 21:14:43] |
| YSS - Posts: 120 |
see attached screenshot, thanks for confirming!!!
Private File |
| [2025-04-23 00:39:21] |
| User584084 - Posts: 348 |
Tradier Futures uses Dorman as their clearing firm. Dorman holds your funds and issue statements but all support is through Tradier. You should be able to use Teton Order Routing or CQG Order Routing to Dorman. Scroll down to the FAQs on the Tradier Futures Website https://tradier.com/individuals/futures Date Time Of Last Edit: 2025-04-23 01:20:15
