Date/Time: Fri, 13 Nov 2026 22:08:43 +0000
access market depth historical files with ACSIL
View Count: 4057
| [2021-09-02 17:50:48] |
| onnb - Posts: 666 |
Just want to confirm something Looking at this link, Market Depth Data File Format: Market Depth Data File Structures Used I can use that header to read the market depth files that are either recorded or downloaded in the MarketDepthData folder With these files, I would have access to all order book updates timestamped to MS Correct? |
| [2021-09-02 18:50:04] |
| John - SC Support - Posts: 48527 |
Correct.
| [2022-11-01 00:43:29] |
| onnb - Posts: 666 |
Following up on this The timestamps are UTC, yes? I noticed that at midnight a new file is created. The first row is a command 1 (reset) and then a list of commands 2 and 3 adding the bid/ask levels. My understanding is that the 1 command can be used to build the initial order book as that is a point to start from scratch, yes? |
| [2022-11-02 20:39:32] |
| Sierra_Chart Engineering - Posts: 25422 |
Yes timestamps are UTC. Not necessarily: My understanding is that the 1 command can be used to build the initial order book as that is a point to start from scratch, yes? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-02 20:40:51
| [2022-11-03 05:25:22] |
| onnb - Posts: 666 |
Periodically though there is an entire writing of the entire order book to the file.
I noticed that whenever I connect to the data feed there will be a 1 command and then a writing of the entire book. I also noticed that the data persisted to disk when I disconnect. I haven't monitored it over a long period so not sure if it writes to a file periodically or not. Not super urgent but if you do get more info/documentation that would be nice to have. |
| [2022-11-04 17:22:05] |
| onnb - Posts: 666 |
For anyone with an interest in researching limit order books https://trade29.atlassian.net/wiki/spaces/GP/pages/145620993/Sierra+Chart+Market+Depth+Converter |
