Date/Time: Sat, 15 Aug 2026 10:34:06 +0000
[Locked] - How convert chartbook back to older version in a smart way?
View Count: 2012
| [2013-04-23 03:46:05] |
| pkhst958 - Posts: 57 |
Hi all, as the newer version of sc does not support my trading I want to convert back to an older version. I have a back up of the PC with the previous sc software, though I would need to convert the chartbook back to the old version (old sc software cannot read new chartbooks). Is there a smart way of doing this? Copy to Excel or similiar? I would like to avoid to re-type the whole chartbook manually. |
| [2013-04-23 03:49:21] |
Refer to Backup Chartbooks here: http://www.sierrachart.com/index.php?l=doc/helpdetails45.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-24 17:34:42] |
| User630531 - Posts: 1 |
Someone sends me a chartbook created with the latest version of SC but I cannot open it with an older version SC 2011 that I currently use. There is nothing wrong with the chartbook since I can open it with the latest version also, but I don't want to upgrade since a few things do not work in the new version. Is there a way to convert this chartbook so I can open it with SC 2011? The link you provided earlier regarding the charbook back up obviously do not apply in this case.
Date Time Of Last Edit: 2020-08-24 17:37:07
| [2020-08-24 17:55:24] |
You just need to use the a newer version of Sierra Chart.
Sierra Chart Support |
