Date/Time: Tue, 17 Nov 2026 01:40:28 +0000
Charts not showing core indicators
View Count: 1051
| [2021-08-23 17:27:20] |
| User208645 - Posts: 6 |
Hello, my current version, 2299 does not show core indicators only candlesticks. Please let me know how to fix this.
| [2021-08-23 19:03:07] |
| John - SC Support - Posts: 48547 |
What exactly are you looking for?
| [2021-08-23 19:32:06] |
The charts do not show the core indicators from greenchart. The orange and thin blue lines, the thick blue line etc. I downloaded the current version and now they are all missing. I had this issue before and was told to use 2135 version but now it says that version won't work either. |
| [2021-08-23 20:10:39] |
You need to ask Greenchart about this. They have had ample time to perform the necessary updates to work with the recent versions of Sierra Chart. We can not keep older versions available forever.
| [2021-08-23 21:35:46] |
Do not contact Green Chart about this. We will allow the use of older versions for green chart users for now. Since we did not realize the impact of locking out older versions. This will go into effect in about an hour. At that time you need to go back to the prior version. Instructions: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-23 21:35:58
