Date/Time: Sat, 14 Nov 2026 01:37:16 +0000
missing files to connect to rithmic
View Count: 798
| [2021-08-23 16:11:48] |
| User130077 - Posts: 10 |
Hi I am trying to connect to a ONEUP trader evaluationg and am getting issues hooking it up, i spoke to oneup and they said it looks like I am missing some files can you help me please. I keep getting a error running DTC server program C:\SierraChart\Rim|DTCBridge.exe I passed an evaluation using the R trader DOM but i really would like to use the Sierra Chart DOM for execution I would appreciate your help. Thank you |
| [2021-08-23 16:15:56] |
| Kza57 - Posts: 13 |
I use the Ritmic direct DTC and also have problems with rithmic on 2299. Try to install 2293. It works for me. I’m waiting for a SC support response |
| [2021-08-23 16:40:51] |
Hi I change the settings to the Rithmic Direct - DTC and rithmic Paper trading chicago Area which solved the issue
