Date/Time: Tue, 17 Nov 2026 01:40:27 +0000
Inquiry
View Count: 905
| [2021-08-23 15:00:34] |
| Michał Choros-Mrozowski - Posts: 4 |
Is it possible to have 2 Sierra Charts open the same time: one with Denali Data ant the second with interactive brokers to make orders through DOM? With regards Michał Choros-Mrozowski |
| [2021-08-23 15:35:13] |
| Kza57 - Posts: 13 |
Yes you can have two separates install of sierra chart. In two different folders. Then run both simultaneously
| [2021-08-23 15:56:23] |
Excuse me and one more thing. I forgot to add that it was about 2 computers, one with Denalli Data and the second one with IB data. Is it possible? Sierra charts on 2 computers live, one with Denali and second with Interactive B data to put orders? |
| [2021-08-23 16:04:49] |
| Kza57 - Posts: 13 |
Yes it’s possible I just take a look in my account control panel and I saw this : Allowed Systems: 0 out of a total of 3 system(s) are currently being used. So I can eventually run 3 Sierra Chart on my computer or 1 on 3 computers |
| [2021-08-23 18:36:00] |
| John - SC Support - Posts: 48547 |
The entry on the Control Panel that shows the following: Allowed Systems: 0 out of a total of 3 system(s) are currently being used.
Is about the number of Sierra Charts running on different computers. You can have as many as you want on the same computer. Just keep in mind that data is dealt with differently. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
