Date/Time: Fri, 20 Nov 2026 02:01:54 +0000
TPO Profile Default Setting
View Count: 1026
[2021-08-23 07:24:48]
Peter Beil - Posts: 19
Hi guys,
attached you can see my TPO Chart within my chartbook with all letters in own column (TPO profile OPEN) which should be my default. However, each time I change the symbol it get's set to standard profile (TPO profile CLOSED) so I need to open it again & again after changing from symbol to symbol.
How can I set "all letters in own column (TPO profile OPEN)" as default in that very chart to avoid re-opening all the time?
Thanks in advance & cheers
Pete
image2021 08 23 TPO Chart (open _ letters in own column).jpg / V - Attached On 2021-08-23 07:24:24 UTC - Size: 300.39 KB - 338 views
[2021-08-23 09:49:19]
We need to get back to you on this.
[2021-08-24 16:54:16]
Sierra_Chart Engineering - Posts: 25445
We will implement a default Input setting for how the TPO Profiles will be displayed.
[2021-08-24 17:50:16]
OK sounds cool - when will that be and how will I get to know as of when it is available and how to set the new default?
