Date/Time: Sat, 14 Nov 2026 01:37:18 +0000
compact tools value window
View Count: 779
| [2021-08-22 19:05:34] |
| ronaknathwani - Posts: 13 |
Is there way to add more data into the compact tools value window, example i want to be able to code the following. 1. calculates the High and low of a candle in dollar or cents amount ? i.e (H - L) 2. works out the amount of shares need based on the dollar risk ? i.e 100 / (H - L) |
| [2021-08-23 17:39:31] |
| John - SC Support - Posts: 48527 |
No, there is not a way to add more to the Compact Tool Values Window. But any study you add will display its value in the full Tool Values Window.
