Date/Time: Sat, 14 Nov 2026 01:37:18 +0000
Using AMP Global for CME Futures Verification from UK
View Count: 1089
| [2021-08-22 17:13:59] |
| SouthUKTrader - Posts: 3 |
Hello. AMP Global have an EU subsidiary, licenced in Cyprus I believe. https://www.ampglobal.com/trading/account_specifications.html is their account page. If I do the funded account with them will that do the direct link to allow me reduced rate futures data ? Thanks very much for your help with this |
| [2021-08-23 01:25:04] |
If you are referring to CME futures data, if they can provide you a CQG account since they use CQG, then the answer is yes.
