Date/Time: Sat, 14 Nov 2026 01:37:12 +0000
how to create dly files from intraday data
View Count: 1146
| [2021-08-21 09:47:52] |
| User785157 - Posts: 3 |
How do I create a "dly" file (so I can see daily candlestick data), from intraday data ("scid" file)? I have a few years worth of 1-minute OHLC data that I imported from CSV using the SC import functionality. When using periods of 4hrs or below, charts load all the data as expected. However, if I switch the period to 'daily' or higher, no data is loaded in the charts. Thanks! |
| [2021-08-23 14:59:37] |
| John - SC Support - Posts: 48527 |
When you switch to Daily or higher timeframe, the default for Sierra Chart is to change to using daily historical data, which is stored in the .dly files. If you just want to see the aggregated data from your intraday data as a 1 day chart, then set the Chart >> Chart Settings >> Chart Data Type to Intraday Chart Only. This forces the system to only use the intraday data, regardless of the timeframe that you have set for the chart. Refer to the documentation here: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
