Date/Time: Wed, 11 Nov 2026 00:44:27 +0000
[Programming Help] - Automatic scaling not respected
View Count: 1104
[2021-08-19 12:58:00]
BenjFlame - Posts: 353
I have a study that produce values within more or less a range of +10.0 / -10.0.
However, when I add it to its own pane and set automatic scaling, I barely see the study because the scale seems is in thousands of points... seems same as ES.
Only way to properly see the study is to set scale to fixed, manual range which I don't want.
How to have the study properly use auto scaling?
Edit: there is only one other subgraph in the study, but it is hidden.
Date Time Of Last Edit: 2021-08-19 13:10:34
[2021-08-19 13:14:45]
User907968 - Posts: 885
Change the hidden subgraph to ignore, as if it's value is vastly different to the ones you want to visualize then this is the reason the display shows as it does.
Date Time Of Last Edit: 2021-08-19 13:16:23
[2021-08-20 19:29:08]
GravisHTG - Posts: 321
with automatic scaling , if you have a lot of study in one part of your chart , you have to Put The same As region option in Scaling to make them not count in the automatic scaling.
Date Time Of Last Edit: 2021-08-20 19:31:15
