Date/Time: Sun, 08 Nov 2026 00:35:05 +0000
price bars got flat after adding horizontal line study
View Count: 956
| [2021-08-17 19:06:20] |
| balkis6 - Posts: 4 |
Hi, I have added horizontal line study with 10 lines (5 filled lines), but suddenly price bars got very flat, its not possible to see volume in them also noticed that horizontal lines from study doesn't want to hide https://prnt.sc/1q73o0w please help thanks |
| [2021-08-17 19:15:58] |
| John - SC Support - Posts: 48459 |
The "flattening" is due to the system wanting to draw those horizontal lines and make them visible. Therefore, it is adjusting the scale to fit them in. Refer to the following for further explanation and the solution: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars We are not sure what you are saying when you state that the "horizontal lines from study doesn't want to hide". Are you trying to hide the study and are unable to? Are you having an issue when you are setting a subgraph to Hidden or Ignore? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-18 18:18:20] |
you got it right, all works fine, many thanks
