Date/Time: Thu, 05 Nov 2026 13:23:31 +0000
Last price value on the right side value scale
View Count: 858
[2021-08-15 20:07:21]
Botan626 - Posts: 294
Is it possible to hide it?
If not, could you make it possible to hide it, without hiding the whole scale?
Date Time Of Last Edit: 2021-08-15 20:07:49
[2021-08-16 09:50:03]
User907968 - Posts: 885
Graphics Settings: Last Trade Price Box
Untick 'enable'
[2021-08-16 12:05:43]
Yes, there is this Graphics Settings option which you can disable by unchecking the Enable option for it:
Date Time Of Last Edit: 2021-08-16 12:05:57
[2021-08-17 09:15:54]
It's not possible to disable 'Last Trade Price Box' for a particular chart, not all of them?
If not, could you make it a seting for it in the Chart Settings?
Date Time Of Last Edit: 2021-08-17 09:30:16
[2021-08-17 14:12:19]
John - SC Support - Posts: 48432
There is the option for this in Chart >> Graphics Settings - Chart, so you can turn off the Last Trade Price Box on a per chart basis. Refer to the following for how to control the graphics per chart instead of globally:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
[2021-08-17 15:02:23]
Great, thanks.
