Date/Time: Sun, 22 Nov 2026 17:20:26 +0000
[User Discussion] - Spreadsheet plotting help
View Count: 2686
| [2013-04-23 00:28:04] |
| M5amhan - Posts: 468 |
anyone know how to plot the triangle a little further (about 1 tick more) above the candle because it hides some of the candle? same with the up arrows, example is attached EDIT: i see how to move it but is different for different symbols, how can i reference 1 tick instead of just 1 thanks Date Time Of Last Edit: 2013-04-23 00:33:38
| [2013-04-23 00:40:31] |
| Sawtooth - Posts: 4362 |
Use a formula like this: =IF(condition,C3+($J$21*2),0) This will place the symbol 2 ticks above the high. |
| [2013-04-23 00:58:43] |
Try these: 1) Go to Chart >> Reload and Recalculate. 2) In the spreadsheet study settings, set the Number of Rows to 1000 or 2000. |
| [2013-04-23 01:00:10] |
Sorry, i tried to delete before you read it i just deleted the ,0 at the end and it is working for all of them thanks for the help though |
