Date/Time: Fri, 18 Sep 2026 10:01:43 +0000
Order Allocation to Trade Accounts - Copy Live to Trading Evaluator
View Count: 1044
| [2021-08-12 00:14:53] |
| nosast - Posts: 324 |
I guess it's currently not possible to share trades between live account (SC/TT order routing) and Trading Evaluator as these are on different connections. Trading on both in different subinstances is needed and therefore trades could not be copied. Would highly appreciate if there is some way to do this. |
| [2021-08-12 05:56:16] |
No this is not supported, but probably you want to have a record of your trading activity you can share with others? That will be supported with the Sierra Chart Order Routing service at some point.
| [2021-08-12 07:22:42] |
Would be awesome if you can consider this as a feature request for the future. I don't want to share my trading activity but want to trade on my live account and have the exact same trades also executed in a tryout account for a prop desk. Would be much easier than switching instances for executions. |
| [2021-08-12 13:58:18] |
| John - SC Support - Posts: 47930 |
We have added your suggestion as a Feature Request.
| [2021-08-12 16:38:04] |
For live trading this is possible if you have e.g. 2 accounts with SC/TT orderrouting - although they are with different clearing firms, right?
| [2021-08-12 18:16:07] |
Yes, this is correct, since the accounts linkage is setup by us and eventually go through the same source at the end (TT). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-12-05 11:02:51] |
| Thaddeus Fulmer - Posts: 71 |
So I want to make sure I understand this: I cannot trade in an evaluated account while having those orders copied and executed through my live account as well? Is the only way to trade in an evaluated account and live account is to create a new instance? Thanks |
| [2021-12-05 11:43:49] |
Yes this is correct. You need separate installations of Sierra Chart for each account and you have to trade them separately.
