Date/Time: Sat, 21 Nov 2026 13:13:58 +0000
[Programming Help] - Overlapping subgraphs problem
View Count: 882
[2021-08-10 17:29:31]
BenjFlame - Posts: 353
On top of chart bars, I put some numbers (as string). There are several on top of each other.
Problem is that when I zoom chart in or out, they will overlap. Since I don't need them to be at precise vertical value, I would need a way to enforce a FIXED spacing between those subgraphs no matter the zoom level.
See image for problem illustration: see how numbers overlap at that zoom level.
Anyway to do so?
Date Time Of Last Edit: 2021-08-11 15:21:32
imageoverlap.JPG / V - Attached On 2021-08-11 15:21:06 UTC - Size: 10.12 KB - 297 views
[2021-08-11 15:18:33]
Completely rewrote the message as i now better understand the problem.
