Date/Time: Wed, 18 Nov 2026 07:18:50 +0000
Deleting Quoteboard Entries
View Count: 722
| [2021-07-30 12:49:36] |
| Atmos37 - Posts: 11 |
Just letting you know that if I delete 1, 2 rows on a quoteboard at a time, it deletes fine, but if I delete maybe 5 or more rows, sierra chart crashes and closes automatically without saving. Not sure if its just me or if others have noticed that.
Date Time Of Last Edit: 2021-07-30 12:52:27
| [2021-07-30 16:48:19] |
We need to look into this.
| [2021-07-30 20:33:30] |
| Sierra_Chart Engineering - Posts: 25439 |
Can you provide us the Chartbook you are using where you encountered this problem so we can test. Instructions to attach: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-07-31 10:57:16] |
See attached. I have it recorded as well.
| [2021-07-31 19:03:04] |
We have identified the problem and we are resolving this.
