Date/Time: Wed, 18 Nov 2026 07:18:49 +0000
[Programming Help] - Forcing study update before the function finishes.
View Count: 709
| [2021-07-30 08:30:17] |
| P3rri - Posts: 16 |
Greetings. I have the following code: closing_time = 0.483;
for(i=0; i<10; i++) { sc.SetChartStudyInputFloat(sc.ChartNumber,sc.Input[0].GetStudyID(), 40, closing_time); int index_last_peak = 0; int PeakValleyType = 0; int StartIndex = 0; int PeakValleyExtensionChartColumnEndIndex = 0; float PeakValleyLinePrice = 0; sc.GetStudyPeakValleyLine(sc.ChartNumber, sc.Input[0].GetStudyID(), PeakValleyLinePrice, PeakValleyType, StartIndex, PeakValleyExtensionChartColumnEndIndex, 0, index_last_peak); Subgraph[i] = PeakValleyLinePrice; closing_time = closing_time + 0.05 //Increasing the time to move the profile more to the right. } The problem is that I am getting the same Peak for all 10 iterations cause the VBP does not update even if I move the ending date until the for loop and the whole study function finishes... Is there a way to force update the VBP so I can get the correct peak for each iteration? Thank you and have a great day. |
