Date/Time: Mon, 16 Nov 2026 11:35:56 +0000
Text on Chart
View Count: 784
| [2021-07-30 08:12:29] |
| User486817 - Posts: 83 |
Hello, 1. I have two spreadsheet formulas as studies on a chart. When a formula sends an alert, i would like for there to be text on the upper right corner of the chart that says "UP" or "DOWN" respectively. Is this possible? Kindest Regards, |
| [2021-07-30 17:34:13] |
Yes this can be done with this particular study: Text Display For Study You would need to use this input with it: Use Text for Non-Zero Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
