Date/Time: Tue, 29 Sep 2026 14:06:17 +0000
Customize Title Bar
View Count: 1889
| [2021-07-29 17:13:01] |
| awakef - Posts: 72 |
Hi there's a way to customize the title bar to make the symbol name short so I can see what I'm typing when I'm changing the bar period? Or change the typing from the title bar to the chart header since there's more space to it and I can customized it better? Thanks! |
| [2021-07-29 17:20:31] |
| John - SC Support - Posts: 48048 |
Refer to the following setting: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-07-29 17:27:58] |
Like you see on the picture I have the custom title bar name DAY WEEK but the symbol name info is still there it doesn't substitute it
Date Time Of Last Edit: 2021-07-29 17:31:07
| [2021-07-29 18:22:58] |
That is the only option at the moment for shortening the Title Bar. And the Typing Text that gets displayed in the Title Bar is only shown there. We will mark this thread as a "Feature Request" in that you want to be able to see the text displayed somewhere else where you can control the length and be better able to see it. We just can not say when we will be able to get to something like this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-07-29 18:25:31] |
Thanks that feature will help a lot ;)
