Date/Time: Tue, 29 Sep 2026 14:06:25 +0000
Using Your Own Data
View Count: 873
| [2021-07-29 16:59:16] |
| User841604 - Posts: 20 |
Hi I need to use the .csv file attached. Buy when I open a New Historical chart and select that file it doesnt go through. I tried importing it also and it doesnt seem to work. Best regards |
| [2021-07-29 17:02:58] |
| John - SC Support - Posts: 48048 |
Your Time fields are not correct. They show the following as an example: 2014-12-01T00:00:00Z Refer to the following for how the field should be formatted: Text/CSV Data Format: Date Format Also note in the section above that one that Date and Time need to be separate fields. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
