Date/Time: Tue, 29 Sep 2026 14:06:25 +0000
Gaincapital issue
View Count: 756
[2021-07-29 16:13:59]
User215020 - Posts: 6
I am getting a error saying
Symbol is unknown and max subscription is reached. I reached out to Gain and they increased the symbol count to 20 and i still get this error. See the attached screen shot.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53224
[2021-07-29 16:38:55]
John - SC Support - Posts: 48048
Select File >> Disconnect followed by File >> Connect to Data Feed in order to ensure that you are getting the updated information from your Gain account.
If you continue to get the same message, then you need to talk to Gain about it, as it would appear that your limit is still set to 10, as those messages come from them (it is not a Sierra Chart message).
