Date/Time: Thu, 24 Sep 2026 22:10:23 +0000
Using AddLineUntilFutureIntersectionEx after a full recalculation
View Count: 1371
[2021-07-19 19:07:09]
@sstfrederik - Posts: 413
I have an issue with the function: AddLineUntilFutureIntersectionEx.
When I use it to plot a line until intercept on some previous bar after a full recalulation the line plots all the way and is not plotted until intercept from the set StartBarIndex.
I would like to use this function on data I only have available some time after the study is fully recalculated.
Can this be resolved?
Thank you
Frederik
See below code example:
#include "sierrachart.h"
SCDLLName("SomeTestingStudy")
SCSFExport scsf_TestStudy(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Test Intercept";
    sc.StudyDescription = "test";
    sc.AutoLoop = 0;
    sc.GraphRegion = 0;
    return;
  int& Testplot = sc.GetPersistentInt(0);
  if(sc.UpdateStartIndex == 0){
    Testplot = 0;
  //Do data processing
  //comment 2 lines below to see plotting working
  if(sc.IsFullRecalculation)
    return;
  //we only plot after a full recalulation has happened ... not working
  for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++){
    int IndexToPlot = 3248; //some index number; choose any //used a 30 days 5 min ES chart for testing
    if(Testplot == 0){
      n_ACSIL::s_LineUntilFutureIntersection LineUntilFutureIntersection;
      LineUntilFutureIntersection.StartBarIndex = IndexToPlot;
      LineUntilFutureIntersection.EndBarIndex = 0;
      LineUntilFutureIntersection.LineIDForBar = 0;
      LineUntilFutureIntersection.LineValue = 4333.75; //some test value
      LineUntilFutureIntersection.LineColor = RGB(0,0,255);
      LineUntilFutureIntersection.LineWidth = 2;
      LineUntilFutureIntersection.LineStyle = LINESTYLE_SOLID;
      LineUntilFutureIntersection.PerformCloseCrossoverComparison = 0;
      LineUntilFutureIntersection.AlwaysExtendToEndOfChart = 0;
      sc.AddLineUntilFutureIntersectionEx(LineUntilFutureIntersection);
      Testplot = 1;
Date Time Of Last Edit: 2021-07-19 19:18:44
[2021-07-20 08:52:25]
We will look this over, but we cannot do it very soon.
[2021-07-20 18:54:45]
I have looked at this some more and it seems that I can make the drawing happen during a self induced recalculation and this function will consequently work as intended. No need to look into this anymore. Thank you.
[2021-11-16 16:24:41]
Understood.
