Date/Time: Wed, 04 Nov 2026 01:36:16 +0000
volumes bar not accurate
View Count: 748
| [2021-06-10 16:17:53] |
| m zamani rad - Posts: 24 |
volume bars are not accurate since this morning ,i have attached a copy and you can clearly see shape of volume bars are changed . than you in advance. http://www.sierrachart.com/image.php?Image=1623329947390.png |
| [2021-06-11 08:47:41] |
It is hard for us to understand exactly what you mean by this. Also understand that this is the September contract and it just began trading so it will affect volume bars.
