Date/Time: Mon, 30 Nov 2026 00:33:31 +0000
Cannot update Sierra Chart + Eurex data not working after rollover
View Count: 816
[2021-06-09 09:37:29]
User206920 - Posts: 28
Im running on 2 issues at the same time, first thing is that I cannot upadate sierra chart at all.
Every line is just Failed to open the file:
Second issue is that after rollover Eurex data are just not working, backadjusting function is not working at all and there are random gaps at start of each day.
[2021-06-09 14:05:58]
We see the following in your log file:
Error: Windows error code 3: Systém nemůže nalézt uvedenou cestu.
The information in this section will apply to the issue you are having:
Software Download: Resolving 'Access is Denied' Errors
But, if you continue to have trouble, you may need to use the Zip installer. Refer to the information here:
Software Download: Sierra Chart Zip Installer
