Date/Time: Sun, 29 Nov 2026 12:09:30 +0000
[Programming Help] - main price not updating when using custom study - acsil program
View Count: 977
[2021-06-03 19:16:53]
szdaniel1994 - Posts: 18
Dear Support,
Thanks again for the great platform and the detailed documentation.
I wrote a custom study (which sets Tick per Volume Bar and Maximum Volume Bar Width Percentage of Volume by Price studies). It works fine using historical data or when scrolling through a chart.
However using it with live data or with chart replay the main price chart is not updating (if I do recalculation of chart it will update the price). I checked the code and it seems without lines 149-156 there is no problem with the main price update.
I attach the code and a picture how it looks like.
Could you please advise what should I try to do?
Thank you
Private File
Private File
[2021-06-09 07:05:02]
Have you had a chance to look at my question above?
