Date/Time: Wed, 18 Nov 2026 18:42:52 +0000
exchange values not matching with charting software
View Count: 899
[2021-06-02 13:49:47]
User272164 - Posts: 3
hello open, high low are not matching with the exchange values there is a lot of difference.
imageBANKNIFTY Future Derivatives & Quotes Options, F&O Analysis .png / V - Attached On 2021-06-02 13:46:36 UTC - Size: 35.91 KB - 336 views
imageSierra Chart 2234 Chartbook3 Global Data Feeds India - DTC .jpg / V - Attached On 2021-06-02 13:46:48 UTC - Size: 849.23 KB - 365 views
[2021-06-02 14:37:16]
John - SC Support - Posts: 48576
First of all, refer to the following:
Historical Chart Prices: 12.2 - Comparing High And Low In a 24 Hour Historical Daily Chart To an Intraday Chart
And also the following:
Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.6 - Differences Between Close Prices on Historical Daily Charts Compared to Intraday Charts
If you still feel there is an issue, then you would need to ask Global Data Feeds about their data.
[2021-06-02 14:45:41]
its not about historical data its about live data during market hours.
[2021-06-02 15:56:04]
We do not know how the site you are comparing against is viewing the data, therefore it's possible that there could be an issue.
But, in the end, you would need to ask Global Data Feeds about the data. We are just displaying what they are sending us.
