Date/Time: Sat, 31 Oct 2026 22:18:12 +0000
data to a csv file
View Count: 1591
| [2021-05-26 16:18:51] |
| coachted - Posts: 542 |
I would like to get information from my tpo chart into a csv file. The information is both static and dynamic. The information also includes both studies and custom studies. I then want the information to be running on a csv file that will intermitently upload to the cload, can this be done? For example I have current hi lo close, prior hi lo close, prior week hi and low, prior month hi and low, prior mid mid vpoc poc, current mid vpoc poc, current value area hi and low |
| [2021-05-26 17:44:02] |
| John - SC Support - Posts: 48377 |
In terms of automatically outputting data to a file, you would need to look at the following study: Write Bar and Study Data To File Although most likely the TPO data you are looking for is NOT included in the study data, as it would need to be stored in a Subgraph, which the items you are referencing are not. Therefore, the only way to get the information you are wanting would be to write a custom study using ACSIL. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
