Date/Time: Thu, 29 Oct 2026 06:47:06 +0000
my data seems like im getting blocks of data every 150ms instead of a constant data flow
View Count: 778
| [2021-05-25 15:00:38] |
| bw5081 - Posts: 4 |
i have read thread mentioning this same issue i am having. they recommended to turn Remote Buffer Delay Send Time to 20ms and this seemed to help the guy fix his issue which is same as i am trying to describe. can you please tell me what settings to adjust so that i can get 20ms delay not 150ms (guess) update rates so my charts and time and sales are moving smoothly and not4x a second? |
| [2021-05-25 16:27:02] |
| John - SC Support - Posts: 48363 |
The item you are looking for is the Chart Update Interval. Refer to the information here: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) But, we do not recommend setting this to a value of 20ms. That is a lot of updating for the entire system. Also note, the Time and Sales Window does not use this update interval, it is a real-time display. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
