Date/Time: Mon, 26 Oct 2026 01:52:10 +0000
[User Discussion] - last pivot - is there any study or code
View Count: 714
| [2021-05-24 14:41:25] |
| User61576 - Posts: 458 |
that can draw lines the same as the yellow I drew manually? looking to place my stops at this price will be happy if you could share your thoughts thanks |
| [2021-05-24 15:11:51] |
| Ackin - Posts: 1865 |
is there any study
Swing High and Low |
| [2021-05-24 19:22:30] |
| John - SC Support - Posts: 48317 |
If Ackin's solution works, then that is good. Otherwise, we would need to know what your criteria is for where you are drawing the lines. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
