Date/Time: Fri, 06 Nov 2026 08:17:15 +0000
Letters/Blocks in Own Column Toggle Expands Profiles, does not Contract
View Count: 1013
[2021-05-22 17:44:16]
User656492 - Posts: 160
This used to work properly, however has of (maybe 2253, certainly true now) right click on TPO chart --> Letters/Blocks in Own Column does not toggle back to off. I have to Reset All Profiles to Standard Profile and then Letters/Blocks in Own Column to contract all others and expand only one.
[2021-09-23 13:17:20]
User560075 - Posts: 10
Found the same thing using later versions. Can you please advise when you can fix this?
[2021-09-23 14:07:47]
We are not observing any problems with this. Update to the current version. :
If you still have an issue we need to get that TPO Profile Chart following these instructions:
[2021-09-24 05:29:42]
Thank you for your response. The latest update has stopped the issue from re-occurring. Appreciate your support.
